which fuel management and intake?
Just bought an 09 Fat Boy.
I'm going to be adding Vance & Hines bigshots staggered
and I was wondering if someone could suggest the best combination
of high performance intake and fuel management system to get the most bang
for my buck.
My previous ride had the SE Pro high performance air cleaner/breather,
and a PCIII
Can I do better than this?
Do I HAVE to get the Harley download before I can add another fuel management system?
Thanks!
for my buck.
and a PCIII
Thanks!
Assuming BSS, PCIII, and SE Pro AC, there was not a single map in their database even close.
Think a map for an 08 would be the same still?
If you can afford it, get a Thundermax with auto tune. If funds do not allow it, a PC V.
K&N is a good choice for AC.
If you change the pipes only or AC only, no dealer download needed. If you change both at same time, dealer download or Thundermax or PC V or...
If it were me and you could only afford so much. The biggest bang for the buck is BSS, a high flow AC, a set of bolt in Cams ( like Andrews 26, SE 203's...) and a PC V. To install cams in your year of bike is not that difficult and you will notice a huge diff as compared to only the AC, BSS and PC V.
Also, is cams a job I dare try to tackle myself? I'm pretty handy with a wrench, but so far I've only done things that
bolted to the outside of the bike. Never cracked it open.
