Chrome Hardware or not....
Ive been looking at and considering the chrome hardware for my engine area, more specifically the primary, transmission, Cam cover, and lifter tappet blcok, and when I feel up to removing the tank I want to do the rocker boxes also. I have considered both the chrome and stainless steel hardware. Have any of you done this and was it just too much chrome? I like the idea but am also worried it would just be too much chrome.
What are your thoughts on this?
The little covers that go over the bolt heads are not an option. I dont like the idea of putting covers over anything and if Im gonna do it I want to go the whole way.
Thanks for your opinions.
Chrome Hardware
I changed out all of the bolts your speaking of to chrome, including all that I could get a socket into, transmission cover, bolts around oil filter, cylinder base, fender bolts, you would be hard pressed to find an original bolt anywhere on my Fatboy. I've had alot of people comment on the sparkle factor. IMHO, I think it looks great, making sure ALL the water is out of the bolt cavities when you wash or detail is a PIA, but worth the look to me. All of the odd bolts I removed, Ace Hardware had the chrome replacements.
Gardner-wescott also makes "kits" for the areas you want to change over...
http://www.gardner-westcott.com/
I also did as the above poster.....Replaced them little by little from the hardware store
I've used chrome bolts in the past... as soon as I put a tool on them, the chrome would crack or scratch and I'd get what looks like rust underneath. I now prefer polished stainless steel. Diamond Engineering has pre-assembled kits for Harleys. They're great to talk to and very patient. They'll sell you a complete set for every bolt on the bike (around $700), or one bolt at a time.
I just checked and an OE kit for a 06 Softail is $156. A 12 pt kit for the same is $241. The OE Stuff is cheaper then the HD Stuff.
