Installing Kury ISO grip help please..
I have the ISO's and I some what took off the throttle side and it doesn't look easy like I figured it would be. How do I take the cables off the stock grips and do the transfer?
I do not have any instructions with these for some reason.
Any help would be appreciated.
Or...have some extra ferrules there for the ones that doe bounce away. It is a pretty simple swap. Just take you time and ask questions if you have any. Loosen the throttle cables and then it should be simple to get the ends of the cables out of the old grip. Repeat in the opposite order after sliding the grip on. Adjust the cables at the adjuster. Done.
