Valve noise... should i be worried
Old 06-09-2009, 01:58 PM
jefnightrain's Avatar
jefnightrain
jefnightrain is offline
Originally Posted by Mark g
Good oil is a help,but if you really want to shut it up? get some upper cylinder lubricant. Lucas makes a good product as well as Klotz. you mix a couple oz. in your fuel with each fill up.
I'll add those noises are normal for a hd motor.
Also most aren't using thick enough oil, check your owners manual and pay attention to oil viscosity vs. ambient riding temp. recommendations.
What is the lucas product called? I have sort of gotten used to the noise the motor makes, but if I could quiet it down, I would be happier.
Old 06-09-2009, 02:54 PM
Mark g's Avatar
Mark g
Mark g is offline
http://www.lucasoil.com/products/dis...el%20Treatment
http://klotzlube.com/storeProdDetails.asp?pi=50
either of the above. I like the klotz as it claims to help stabilize the oxygenated fuels,helps in storage(preservative),and can boost octane a point or two. My bike seems to like it.
hdrider91
10-25-2015 10:54 AM
DIRERIDE
Engine Mechanical Topics
09-12-2014 11:16 AM
DStin
Exhaust System Topics
04-11-2013 05:32 PM
j33ptj
11-25-2012 09:40 AM
steelpony5555
12-31-2010 11:11 AM
Quick Reply: Valve noise... should i be worried
