Quick fix for fuel line
I have and 06 Deluxe and in the process of changing out my handlebars I broke the quick disconnect fitting from my fuel tank to the fuel injection. I barely moved my tank and the plastic fitting to the fuel injection broke. I called my local HD store and of course they didnt have it and it was 45 bucks. All I did is bought a new 5/16 fuel hose and hose clamp from autozone and installed it on the fuel injection side. I reused the metal quick disconnect fitting to the fuel tank and it works like a champ. It cost me under 10 bucks to fix my problem and was on the road in a day instead of two weeks. For those who are worried about the looks, you cant even see the small hose clamp because it is tucked away under the fuel tank. I hope this helps some people out.
Got any pics of it?
Lots of us have moved the tank 'just a little' and broke the line.
But when I did it there was no fixing it because it broke at the very end by the injectors.
It didn't leave anything to put a hose or clamp on.
But I would be interested in seeing how you did it, just in case I get another case of the stupids and break it again.
Did it break at the tank end or the injector end?
I have seen several lines that were broken, mine included and they all broke at the injector end and didn't leave enough sticking out to hook anything too.
In fact mine broke off flush with the fitting and I had to use a spring hook to get the little piece out so I could install the new line.
What annoys me most is I lost the little piece.
If I had it I could have used a friends lathe to make a new longer one out of brass or stainless steel and used some pressure line the way you did.
Might even make up a few extras for other guy's to use when they break theirs. Cause it does seem to be a very common problem.
i did the same and looked for the delfi fitting. the replacement hose is a one peice that is molded so you cant replace the hose. if you did what you said keep in mine 2 issues, you need to have fuel line rated for injector and with the quick disconect on the fuel injector. the next time something breaks it will be the fuel injector and that will cost way over the $45.
TK the fuel hose is replaceable on my model, each end has a hose clamp. When you say fuel line rated for the injector, do you mean the psi rating? If so, the fuel line is rated at 50 psi which is plenty and I dont think that line is pressurized. If it is pressurized it isn,t much.
Ron
there is fuel line and then there is fuel injected fuel line. it is preasurised as it is after the fuel pump. you need to make sure the hose is rated for fuel injection. the specs are 55 to 62 psi in the harley manual and that is the spec for the fuel preasure and not the hose. it can rupture on you if you dont get the right hose. it can be found at most auto parts store
http://store.summitracing.com:80/par...5&autoview=sku
