Quick fix for fuel line
Old 06-04-2009 | 09:28 PM
anubisss's Avatar
anubisss
Broke mine when doing the bars too. I also broke the crossover. it was fun learning about all those gas lines as gas poured at my feet.
Old 06-04-2009 | 09:57 PM
tlb's Avatar
tlb
I broke mine too, the new one was different than the orginal hose. I would replace the line to the injectors and not clamp them. where mine broke I could not of repaired it anyway.
Old 06-04-2009 | 10:29 PM
gquist's Avatar
gquist
Unhappy
Good fixes guys but please remember, If that line comes off or leaks when it is 90 degrees outside and you are going 30 mph down the road, you got about 5 seconds for 3rd degree burns, $45.00 maybe isn't that much to spend on the factory line? at least that line has proven itself in all conditions.
Old 06-04-2009 | 11:24 PM
chad pickens's Avatar
chad pickens
My 06 nt has quick connect fittings but mine has a rubber line with clamps. it has been there since new
Old 06-05-2009 | 12:48 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
EXCEPT for dummy's who forget to disconnect it before trrying to lift the tank up.
Just a point of curiosity, but I wonder how many factory trained dealer techs have broken the same line/fitting the same way we all did.
Old 06-05-2009 | 06:38 AM
tk353's Avatar
tk353
i got the new line and the new 1 piece molded line looks better so it is like adding a mod to a harley and for $45 it is cheap. i am just glad it broke instead of the fuel injector. ($450)
Old 06-05-2009 | 06:56 AM
Notgrownup's Avatar
Notgrownup
I think on some newer models you can use the ford fuel line quick disconnect... i opted to by the $45.00 part like some sucker....One born every minute they say...
Old 06-05-2009 | 07:11 AM
If it works on one Softail it will work on all Softails.
They all use the exact same part, I think even the Deuce (FI models) with its odd tank used the same part.
I would be interested in seeing if the Ford parts will fit. That would open a new option for us to swap the line out for one made up using the Ford ends and some braided line in between.
Old 06-05-2009 | 01:03 PM
cmueller2423's Avatar
cmueller2423
Stage I
Broke fuel line on 07 Dyna, new repalcement line from HD is much stronger, the part number suffix changes to identify a improved part, be sure to get latest.
randazlr
13
07-13-2017 10:36 AM
cptseawolf
02-26-2017 03:49 PM
1957buick
10-28-2016 10:36 AM
Psychosis
01-16-2010 10:26 PM
Bogey_52
03-17-2009 11:08 AM
Quick Reply: Quick fix for fuel line
