belt tension
Old 05-28-2009, 11:07 AM
trigg's Avatar
trigg
trigg is offline
2nd Gear
Default belt tension
what would be the proper tension for the drive belt be thanks
Old 05-28-2009, 11:09 AM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,948 Likes on 1,932 Posts
If you can twist the belt at a 45 * angle it is right. This is while NOT sitting on the bike.
__________________
Old 05-28-2009, 11:12 AM
Ruralmed's Avatar
Ruralmed
Ruralmed is offline
08 Softail manual says 1/4-5/16" deflection at 10lbs as measured with belt tension guage, if on jiffy stand.
Old 05-28-2009, 11:44 AM
128auto's Avatar
128auto
128auto is offline
+1 on the 45 degree angle trick
Old 05-28-2009, 11:46 AM
oct1949's Avatar
oct1949
oct1949 is offline
I think I read that the dealers have the 10lb gauge to use..
Old 05-28-2009, 11:49 AM
VTwin-Goodies
Sponsor
I learned the 45* angle trick from PocoCj. Old school master.
Old 05-28-2009, 11:57 AM
oct1949's Avatar
oct1949
oct1949 is offline
Default Don't see this one.
Need to explain this one a little more!, is this with fingers or using a tool?
Seems like it would be a ball park way to adjust.
(example)I could use an Adj wench across the belt and twist it 45* no matter how tight the belt was.
Old 05-28-2009, 02:21 PM
Dorkman's Avatar
Dorkman
Dorkman is offline
This is with fingers. Works fine. Hardly any stretch in these belts anyway. The Harley gauge is a worthless overpriced piece of junk.
Old 10-14-2009, 07:36 PM
zer0t's Avatar
zer0t
zer0t is offline
I know this is a bit old, but where along the belt do you twist 45*?
thanks.
Old 10-14-2009, 11:08 PM
Hrd Rider's Avatar
Hrd Rider
Hrd Rider is offline
+1 on the 45 degree with fingers, I learned that a long time ago.
Quick Reply: belt tension
