belt tension
Old 10-15-2009, 12:41 AM
plane's Avatar
plane
plane is offline
The guage seems to work fine for me.
Old 08-21-2016, 08:29 PM
hogz n rodz's Avatar
hogz n rodz
hogz n rodz is offline
3rd Gear
I have a 2011 deluxe I don't see a widow on my belt guard how am I to no proper deflection
Old 08-22-2016, 06:03 AM
S.D.M.F's Avatar
S.D.M.F
S.D.M.F is offline
Old 09-06-2016, 09:45 PM
hogz n rodz
3rd Gear
Thank u
Old 09-06-2016, 10:00 PM
JesseDyna's Avatar
JesseDyna
JesseDyna is offline
I was never so unhappy with belt tension as when I used the "proper" tension tool (directions followed to the T). The twist method wins the day.
Old 09-07-2016, 07:50 AM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,572 Likes on 1,594 Posts
use the proper tool and follow the directions in the service manual ( you do have one, right) you will get alot of miles out of your belt drive system if you do this. it's a very touchy adjustment if you want it correct.
Old 09-08-2016, 08:21 AM
bolt54's Avatar
bolt54
bolt54 is offline
Working in an indy shop that only services harleys, I see many bikes come in with the belt tightened so that belt feels more like a guitar string. We get very few broken belt jobs but we get many bikes (2 in there as I write this) with trans main shaft seal leaking because the belt was run too tight for too long, the worst case being a customer ignoring the leak until he smoked his trans. I would rather err to a little looser than spec.
Old 09-10-2016, 08:01 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,732 Likes on 2,005 Posts
Originally Posted by Dorkman
This is with fingers. Works fine. Hardly any stretch in these belts anyway. The Harley gauge is a worthless overpriced piece of junk.
Glad you came along to tell me that the tool I've used for the past 25 years to set my belt tension is "worthless, overpriced junk". Whatever would I do without you?
P51Driver
2018+ Softail Models
07-30-2019 06:22 PM
Bill Murray
05-02-2013 12:22 AM
37sportster
03-26-2011 08:49 AM
seoris
10-16-2010 06:41 PM
spizzyman
10-11-2008 07:56 PM
Quick Reply: belt tension
