Signal Connection for an H-D Tach on '07 Deuce?
I have installed an H-D tach on my "07 Deuce. Powered it up but the tach has no signal. The papers tell me to connect to pin 3 on connector 39B (at speedometer) but after checking the wiring schematics, pin 3 doesn't connect to anything. Any suggestions?
Thx
Thx
According to my install instructions you must hook it up to the data link under the seat. Shoot me an email at tnharley@comcast.net and I will send you my instructions and maybe they will help you. Jerry
These new speedo/tach combo's are plug and play, I thought. So running a wire back to the ECM doesn't seem right.
Thx
Lifted the dash off the tank and used a small mirror to look inside the male connector on the tank. Sure enough, pin 3 is there. Looking at the connector itself, I noticed that the female pin 3, which I had initially installed, had pushed back. I pulled the locking pin out, reset the pin and locked it back down. Whamo, the tach worked.
So, the signal comes in from pin 2 and is sent out of pin 3. The service manual shows nothing on pin 3 from the speedo, but the signal is there.
Cheers!
Cheers!
07, 2007, 2008, 2009, connection, custom, deuce, disassemble, harley, hd, pinout, signal, softtail, speedometer, tach
