Andrew's 26H cam
Andrew's 26H cam
Anyone ever put an Andrew's 26H cam in there 88B or 96B motor? If so how did it do compaired to stock? Where did you see an gains or losses in the power curv? Thanks for the input...Not to sound pricky but I dont want to hear about other cams just this one. I have bought one just waiting to put it in and wanted to hear the good and or bad so I know what I am in for thanks.
26's in a Night Train wouldnt be my first choice.
Its a TQ cam. A 2-up Bagger cam.
Is your bike a 96" or an 88"?
If its a 96" do a set of 37's with a .030 gasket and get the heads milled to make at least 10 to 1. More bang for your buck there IMO.
If you have an 88" make it a 95" and do the same 37 build. Its gonna make you happier in your lighter than a geezer glide Train!!
Post that dyno!! I would like to see that
The 26's fall off early. They are generally regarded as a bagger cam. To each his own. I say go with whatever you want...I tend to think a set of stock heads milled and lightly ported with .030 gaskets and a set 37's would make for a "Funner Riding" Train.
Me personally I cant see shifting a non bagger bike so early. I like to wind em' out and let em' eat!!
The 37's work best with a compression bump and some headwork....
The 26's from what I know can get away simply being a drop in cam and dont need the compression and or headwork that some of the other grinds will have to have just to work right if not well. So they are like dropping in a 203 and not touching the heads maybe?
37 builds are about the most popular non-bagger builds going right now with lots of motor shops, and for good reason. They make big Tq and big HP with relatively minor headwork and they shine on the dyno....Guys spending a few grand or 5 on a strong stage 3 build want to see big dyno numbers. That seat of the pants Chit is all good until you drop 3-4-5-6 grand on your bikes motor. At that point everyone wants to see big numbers on paper and will fight kick, fight, scratch and spend another grand or two just to find 6 more pounds of Tq or 5 more Hp!!!.
26's in a stock 96, no headwork, is a good choice. Contact Kbore as he recently installed 26's in I believe an 88". These bolt in cams will not rip your arms off or win races but will wake the motor up in the low to mid range, pull better than stock above that and make for a better ride - especially when riding 2up.
I run gear drive 26s in my 2006 Deuce - light bike, I ride solo, no baggage and certainly not a bagger.
Poor choice, huh?
But I love them. I can count on one hand the number of time I've revved this bike over 5K. Power up there doesn't matter to me, cause I'll never use it. But this bike will pull from 1800 RPMs and doesn't stop before 5K. If it drops off over that RPM, I'll probably never know and certainly never care. I have other bikes for that, thanks.
Poor choice, huh?
Poor choice, huh?
Poor choice, huh?
