07 night train fuel pump issue
hiya
my 07 night train broke down as in when i went to start it to go home it wouldnt start, it turns over ok but just wont start, the recovery man told me it was the crank shaft sensor, so i duly purchased and fitted this myself, i have already checked that there are no fuses blown, i spoke to harley who told me it is the fuel injection relay, now although this they tell me is a cheap item, there is no fuel injection relay, there are two with the fuse box but neither is this, also when tryin to order one from a different dealership they said it doesnt exist
when i turn the ignition on you cannot hear the fuel pump buzz as you would normally before starting the bike
i'm a bit lost as to what to do now as i cant afford to send it to the hd dealer at the mo same as i cant afford to keep buyin endless parts to try, i alreadt have one spare sensor i dont need
any help or advice or any similar experience i would be grateful for
15a fuel pump fuse, have to love a harley manual. got mine used in the forums for 30 delivered.
if no voltage on the fuse then it goes to a system relay that is controlled by the kill switch. if you dont have voltage on the kill switch i will look further for the source
just plain john
08-28-2013 09:08 PM
