Rush - baffle removal and repack
Just pulled the baffles out of my road king (which is basically same for baffle removal). after taking out the bolt my baffles would turn a little but couldn't pull them out. I started the bike up to heat the pipes so they would expand...sure enough I was able to pull the baffle out with a little force, but it wouldn't budge until I heated it up.
Mine came out easy enough. Just remember that the screw on the underside of the pipe doesn't screw out. The nut inside the pipe screws off. Almost stripped out the screw before realizing this.
I used masking tape to hold the matting together while re-inserting the baffle. Same thing the factory does.
______________________________
2008 Heritage Classic: His
2008 Deluxe: Hers
2008 Deluxe: Hers
cut the length +1in and don't wrap tight...use 3/8 masking tape to wrap and don't worry about the heat.
after done it is really good.
take out screw and the baffle came out easy. just a little twist and its out. watch out for burrs on baffle, install the same way and muffler..
