What tool did you use to tighten / untighten Adjusting Nut for Steering Head Bearing?
Old 04-29-2009 | 08:36 AM
danfrompa's Avatar
danfrompa
Default What tool did you use to tighten / untighten Adjusting Nut for Steering Head Bearing?
The steering head bearing adjustment was needed as the front end started to wobble a little. I only have 4K on the bike and I am assuming that HD dealer did not adjust as a part of 1K service, STEALER SHIP!!!!!
I tightened a "Adjusting Nut" a little and there is no more play / wobble. I had to make a flat metal bar and tap on it with my hand to rotate a little. A washer underneath STEM NUT was piece of junk, I have 07 Night Train. I am going to get a new and improved thicker washer from HD (Part # 45727-08).
Anyhow, where can I get a proper tool for "star like looking adjusting nut"?
1. Where to get it?
2. Name of the tool to ask?
3. Price if you remember?
Thanks,
Dan.
Old 04-29-2009 | 08:50 AM
DaddyKnuck's Avatar
DaddyKnuck
I use a brass drift.
Old 04-29-2009 | 09:53 AM
stupid_rope's Avatar
stupid_rope
Channelocks
Old 04-29-2009 | 05:34 PM
WFA's Avatar
WFA
I use a blunt flat blade screw driver tapped with a small hammer for the fall away adjustment nut and a 1 1/2 inch socket and torque wrench to tighten the stem nut to 70-80 ft lbs as directed by hd. Also used the heavy washer you noted. Instructions state to torque the stem prior to adjusting fall away. Follow everything with a grease job.
Old 04-29-2009 | 06:35 PM
crazybastid83's Avatar
crazybastid83
Old 04-29-2009 | 07:14 PM
yankeeflyer72's Avatar
yankeeflyer72
One that fit...
Old 04-29-2009 | 07:26 PM
crazybastid83
No, start with a grease job.
Old 04-29-2009 | 07:31 PM
anubisss's Avatar
anubisss
Big adjustable wrench. BFW.
Old 04-30-2009 | 10:46 AM
michael95688's Avatar
michael95688
What stupid said... Channelocks. Not tight, just snug.
Old 05-01-2009 | 08:52 AM
stupid_rope
Grease jobs in Korea are fun...not that I would know
Quick Reply: What tool did you use to tighten / untighten Adjusting Nut for Steering Head Bearing?
