How about adjusting the cable tension first? It's easy to adjust. I would carefully open the housing (remove 2 hex bolts) and adjust the tension of the cable... I suggested removing the housing so that you can actually see the cable with your eyes!!!
You don't need to open the housing to adjust the cable tension.
I have the PM Contour grips and they squeaked, so when I took my bars apart before I put my grip back on I greased my right handle bar. So far so good.
