Deluxe Auxiliary Lighting Kit question
Thanks Low, My bike thought it was a sailboat. I had it covered and a gust of strong wind knocked it over, resulting in a crushed passing lamp, broken mirror, broken rear turn signal and a dented gas cap and a chewed up master cylinder cover. No damage to the tins as far as I can tell. Thanks Mother Nature!
Hey Low, I was looking over my damaged passing lamp and noticed two connections coming from the back of the lamp that have a male end on them.......what the hell do they connect to? I have a wire that apparently comes from the back of the housing which I assume is a ground wire that connects to the single wire coming up from the turn signal but don't see anything for the two connnectors from the actual lamp to connect to. Does the intructions show that?
Steve, Now that I think of it, the stock m/c cover is black...correct? I put chrome controls on, which has a chrome m/c cover, when I had the front end chromed. Thanks for the offer though but need a chrome cover.
as for the wiring, when I took the damaged housing off the bar there was a plug attached to the inside of the housing with a female connector, there also is a wire coming up from the turn signal thru the mounting bolt that connects the bar to the arm above the turn signal. Now when I look at the back of the actual lamp there is two male connectors on the back. I assume you match the males with the females, however, which one to which, or does it matter?
