FXSTC 07 to 09 Fuel Tank Swap
As a mater of fact.....yes
First drill several guide holes from the top side just out from the bracket.
Remove the section marked with the die grinder from the tank.
Then remove the 4 spot welds holding the bracket from the bottom side. Being carefull not to get into the bracket itself. Smooth the bottom of the bracket with your grinder.
Now to remove the bracket from the tank you want to use.
Using a dremmel type grinder go into the new tank through the pump/sending unit access window .
Remove the spot welds from unwanted bracket.
Smooth the inside of the tank to accept the bracket previously removed from the other tank.
Spot weld the brackets in.
Sounds harder than it is. Cheaper than a new pump set up.
frostfamily923
09-28-2008 03:44 PM
