SE backplate
04-03-2009, 10:31 AM
SE backplate
I'm looking to buy a used SE backplate. Does anyone know if the 3 stock bolts will work to fasten it to the EFI?
Thanks
04-03-2009, 10:45 AM
I have one I just took off my carbed bike, and it was held on by the three bolts that are studds that the air cleaner attaches too. On mine it states that it is for ALL models, carb or EFI, so I am pretty sure you will not need any of your stock parts.
04-03-2009, 10:54 AM
no...what I'm asking is will I be able to use the 3 stock bolts to fasten the SE backplate to the EFI
04-03-2009, 10:59 AM
I guess you could if you are not going to be using a K&N type filter...Here is a picture with the filter element off.
Quote:
Originally Posted by
SD Night Train
04-03-2009, 11:15 AM
I will be using a K&N filter....so if it doesnt come with those 3 bolts what are my options?
04-03-2009, 11:27 AM
Not sure if they are available from the dealer by themselves??? I guess you could use a threaded connector and a long set screw???
I have a new set and filter that goes with a stage II that I am not going to use. Any interest in those?
SD Night Train
04-03-2009, 11:47 AM
I'm waiting to hear back from a couple of dealers now....will let you know.
thanks
04-03-2009, 11:54 AM
You can buy every piece separate from the stealer...
04-03-2009, 01:51 PM
I wonder if the plate has changed any in the last few years....who knows how old this backplate is.
