im in the process of buying a set of the strut mount bullet lights and want to know if i need there load equalizer. i have the harley tri bar led tail light that im going to install at the same time. if i need the equalizer, should i buy the adapter for the equalizer so its an easy install. if anyone has any experience with these products could you give me some info on the install of the load equalizer and the adapter. thanks, john
edit: i have an 08 night train if that helps
Dont know if you already have LED, if so u wont need the equilizer. Now, most newer bikes come with rear led lights however the front are still the regular bulb.. I installed LEDs upfront with out the equalizer and have had no problems and no rapid blink, dont know. But im sure someone in here will chime in and give u better info than me.. good luck
there is three plugs in the tri bar 1 is brake the other two are your blinkers.............unplug the stock blinkers and cut the wire and wire your new ones to the plug and plug it back in..............
