2008 Fatboy Performance Mods
Hi guys,
I am a new Harley owner, in fact I am a new motorcycle owner all together so I'm not too familiar with the engines etc which is why I am here . I want to do some performance modifications to my fatboy (2008), but am confused as to where to start. Currently the only thing done engine wise is some Rush slip on pipes and that's it. Ideally I'd like to go with a big bore kit (bump it up to 103ci or maybe 113ci) but after reading up on the screaming eagle kits I've learned its better to go with a different brand. So I am wondering if someone could point me in the right direction as far as what brand kits are the most popular, where I can buy it, and what other mods I should do to my bike in addition to that? Thanks guys!
Well i suppose the next step to do is a stage 1 or 2 and a fuel management. i personally use a PCIII, but considering the mods you are looking to do you may want to go with a S.E.R.T. (Screaming Eagle Race Tuner) w/dyno, it has the most ability to accommodate the mods you are looking to do. I can't really comment on the S.E. Kits, havn't heard pos or neg feedback. but you will get lots of different answers to your question. Hope this helps. congrats on the new scoot and welcome to the forums.
i have an 05 which comes with a smaller engine and a 5 speed instead of the 6 speed you have, I did the stage one and cant imagine wanting or needing more power, i am also new to bikes etc. started with a sprty 883 that is now 1200, but the fatboy i have is sweet and powerful, spend the money on cosmetic mods after stage one...but thats only my opinion....good luck
i have an 03 night train that came stock with an 88" and ended up putting a 95" kit in it. it's a HUGE difference. stock 96" has (about the same hp as an 88" but more tq) 62 hp and 77 tq. i've got S&S 585 cams (a pretty aggressive came), S&S gear drive cams kit, SE flat top pistons, SE puahrods, SE air cleaner with k&n filter, SERT, Hooker Troublemakers (had it tuned and dynoed with python3 pipes), hiflow oil pump, new cam plate, harley oil cooler (hardly ever get about 205 degrees), cleaned up the heads and put new springs in them (no real head work, but if i did it would be another easy 10-15 more hp and tq). and had it sert tuned on the dyno. i ended up with 91 HP 96 TQ, after riding my bike for so long i don't know if i could go back to a stock bike. if you have it dyno tuned check around and ask around. there are a lot of place the tune........ and they are some places that really tune. make sure you fine a place that knows what they are doing and talk to the tuner. i've read a lot of people have to get there bikes tuned 3 or 4 times because they didn't get a good tune, or the tuner wasn't any good. i good tuner by a good tuner make all the difference.
i sent you a pm
i sent you a pm
Its all about money and how much you want to spend. If budget minded, finish stage 1 with A/C and PC V, or SERT or ... If ya want more, try adding a cam (Andrews 26 or ?) with adj push rods. Your 07 bike is much easier to install a cam than other years and can be done yourself.
Since you are new to bikes, my guess is this would plenty for you and you will notice the diff!
smokin03 below is thinkin kind a what I am thinkin...
Hi guys,
