Heat Management system
Old 03-29-2009 | 08:01 PM
pat112's Avatar
pat112
Default Heat Management system
Hi, there, I have an 08 Night Train. Does this have this system or is it availiable as a download?
Thanks.
Old 03-29-2009 | 08:16 PM
DyNaBoB's Avatar
DyNaBoB
yes it has it..............you will know when its hott in traffic and starts running like chit cuz it shuts down a cylinder
Old 03-29-2009 | 08:24 PM
pat112's Avatar
pat112
Thanks for the info.
Old 03-29-2009 | 09:12 PM
agapsdiver's Avatar
agapsdiver
My 2003 NT goes thru:
Phase 1 - At approximately 320˚ F the ECM will gradually reduce engine idle speed until the engine temperature drops or the engine reaches 800 rpm.
Phase 2 - If engine temperature reaches 338˚ F the ECM richens the air/fuel ratio to provide additional cooling.
Phase 3 - If the engine temperature reaches 356˚ F fuel injector pulses are interrupted. The air drawn in and expelled helps cool the engine further. Since there is no combustion it would be perceived as a misfire. This third stage will only happen when the motorcycle is stationary.
Old 03-29-2009 | 11:08 PM
SD Night Train's Avatar
SD Night Train
if your bike is hitting 320 degrees you have some serious issues...did you mean 220?
Old 03-29-2009 | 11:21 PM
Other Sheep's Avatar
Other Sheep
320 is not refering to oil temps. I believe it's the head or cylinder temp.
Old 03-30-2009 | 05:53 AM
agapsdiver's Avatar
agapsdiver
My bike's never gone over 230...
The info I gave is a quote from a HD Tech memo.
Old 03-30-2009 | 01:19 PM
tk353's Avatar
tk353
mine runs the head at 210 to 220
Old 03-30-2009 | 01:42 PM
SD Night Train
are you referring to this as your oil temp?
Old 03-30-2009 | 05:27 PM
tk353's Avatar
tk353
no, it is what i read with ir temp reader at the cooling fins. the chrome top is about 120 to 130. the heat shields are about 120 to 140. the exhaust temp is about 240 to 340. tire temp is about 110 after a ride. the temp reader are bout $20 at the local hobby shop.
Quick Reply: Heat Management system
