Wolo Air horn...Holy Crap!
I got the Stebel... it holds the patent that Wolo uses,
or Wolo slaps their logo on it..so they are basically the same.
Harley's chrome version (69423-05) costing $139.95 is also made by Stebel.
You can get the Stebel for $35...
Painted mine Wrinkle Black to match.
Try the mini beast. It comes in a VERY nice square chromed case. Both are actually the stebel horns... The mini beast is LOUD and comes in a nice box..I put one on my intruder before i sold it. I intend to put one on my softail soon. It gets attention for sure but looks better than the wolo
I have a great wife...she'd help me install anything I get :-) Yesterday we installed Hooker Troublemakers. We've installed rotors, stators, tires, chrome parts..stripped wiring harnesses.. I've got it made!
It was an easy bolt on to the bracket that holds the cowbell. I used the wiring harness that is completely plug & play. Very simple install. The Bad Boy I have is the all chrome version & came with just the relay. The Stebel & original Wolo did not completely chrome the compressor side. I believe the Mini Beast II comes with the relay, wires & connectors.
http://www.twistedthrottle.com/trade...view/2867/539/
I also found a thread in the touring section (Dawg's the man!) that shows how to separate the compressor and horn and still utilize the stock horn cover. I wouldn't know where to put the compressor, but here ya go.
https://www.hdforums.com/forum/touri...-question.html
Hold the presses!!!! I just got the Mini Beast II from Eastern for 139.00 shipped. It came complete with the pre-wired harness. The fuse & relay were already installed & all the wires were encased in a wire insulation tube. A easy 20-30 minute install, unbolt the old horn & bracket, connect the harness to the battery, plug in the wires, screw the spacer onto existing bracket stud, tighten Mini Beast bracket allen bolt, tie wrap a few wires & cover your ears. As loud as my Bad Boy & looks fantastic. I just ordered another for the 06 to replace the Bad Boy as it looks soooooo much better. Be sure to put some electrical tape over the connectors. My first toot must have grounded an exposed connector & stuck the horn open. My ears are still ringing as it took about 30 seconds to pull the right wire in my garage
This is a really nice item that's worth the $$$$$.
