tyre pressure
Old 03-29-2009, 09:55 AM
hogdiver96's Avatar
hogdiver96
hogdiver96 is offline
Default tyre pressure
Sorry i know i need a owners manual but can anyone tell me front/rear tyre pressure for 07fxstc...just went for a quick blast and tyres all spongey....
Old 03-29-2009, 10:00 AM
crazybastid83's Avatar
crazybastid83
crazybastid83 is offline
If you have Dunlops, I would put 38 lbs front 40 lbs rear.
Old 03-29-2009, 10:09 AM
hogdiver96's Avatar
hogdiver96
yes i have Dunlops.........thank you very much
Old 03-29-2009, 10:29 AM
snowmass's Avatar
snowmass
snowmass is offline
I almost started a thread on this same topic. The FX front end means a thinner tire with smaller contact patch than something like a fatty or heritage. My owner's manual says 38 in front, but when I bought mine the dealer said "HD says 38 front, we recommend 30". He didn't say why. I assume that with 30 lbs he is trading a bit of extra wear for maybe better traction and braking. So I normally run something in between, like 33 or so.
Like you, I'd be interested in other opinions.
Old 03-29-2009, 12:45 PM
Archer1968's Avatar
Archer1968
Archer1968 is offline
FXST/B/C should be running 30 front & 40 rear, on stock tires unles you ride two up then 2 lb's higher in the back.
Old 03-29-2009, 06:48 PM
snowmass's Avatar
snowmass
snowmass is offline
Archer, I didn't ask the dealer but I'll ask you. Why 30 in front when the owner's manual says 38? As I said, I have my theory but...
Old 03-29-2009, 07:00 PM
anubisss's Avatar
anubisss
anubisss is offline
A higher pressure will yield a bit less traction, but much longer life. 30 sounds excessively low to me. I run my front at 42 and my rear at 40, although I am sure my bike heavier than a standard softy as well. Experiemnt with different pressures and see how it feels.
I used to ride sportbikes in the canyons at excessive speeds and one friend would always run a bit of a lower pressure in his tires to make them stick a bit better. The less pressure, the bigger the contact patch.
Old 03-29-2009, 09:04 PM
rickb's Avatar
rickb
rickb is offline
Book says 30 front 40 rear
Old 03-29-2009, 10:01 PM
snowmass's Avatar
snowmass
snowmass is offline
I just got my owners manual out and looked again. It says:
30 front/ 38 rear for solo,
30/42 for 2-up.
It was the dealer who suggested 38 in the front instead of the 30 in the book. I had it backwards up in that earlier post when I was wondering about the difference.
Old 03-29-2009, 10:17 PM
2wheeltom77's Avatar
2wheeltom77
2wheeltom77 is offline
I've always run 30 front and between 38-42 rear. My front overall wear is fine, though it's choppy. I noticed it with about 7000 miles on it, and a few buddies said it was somewhat normal, but I think it's the new tread design myself.
Quick Reply: tyre pressure
