Apes wont stay tight!
03-22-2009, 08:25 PM
Just installed the gooden tite poly bushing kit on my flstsc to eliminate the play in my apes. Everything was fine today until my bars became loose again! When i put everything together i made sure it was tight as possible. should i consider welding my bars to my risers to eliminate the play? Any suggestions? thanks
03-22-2009, 08:27 PM
emery cloth around the bars
03-22-2009, 08:41 PM
Quote:
Originally Posted by
tomhummer
+1 emery cloth works pretty good even over railroad tracks etc. no slippage.
03-22-2009, 08:43 PM
I've used the emory cloth,but now have cut a couple of thin strips from an aluminum can and wrapped the bars with that.Seems to work better so far
03-22-2009, 09:11 PM
Should the grit of the emory cloth face the bars or face the risers when using it?
03-22-2009, 09:21 PM
Face it to the bars....or do the Alum can deal...I had ta do the Alum strip once,worked well,never tried the emery cloth before...
03-22-2009, 09:28 PM
i currently use a diet coke stips work great no more movement
007FXDB
11-23-2015 11:13 AM
bigblock59
09-09-2013 06:36 PM
TexFF
11-21-2012 09:13 AM
Voony
04-04-2011 10:39 AM
Alain
05-03-2010 11:06 PM
