Relocated Coil and horn, GOODBYE seat post!!!
Old 03-20-2009, 02:57 PM
Cheesecake's Avatar
Cheesecake
Cheesecake is offline
Looks great.... I'm going to have to look at mine....
I'm already in he process of relocation the horn... I was going to move it to the front down tubes.... where did you mount it under the tank?
Old 03-20-2009, 03:01 PM
dusty2221's Avatar
dusty2221
dusty2221 is offline
It is directly above the carb manifold, right under the backbone of the frame. It squeezes right in.
Old 03-20-2009, 04:00 PM
squirrelu's Avatar
squirrelu
squirrelu is offline
Hay dusty nice job looks good were did you get the wires from did you use the stock horn or buy a new one look good.
Old 03-22-2009, 11:55 AM
anubisss's Avatar
anubisss
anubisss is offline
Pics of the horn location?
Old 03-22-2009, 02:32 PM
dennyo's Avatar
dennyo
dennyo is offline
Received 1,059 Likes on 633 Posts
Looks Great... I'm tryin to think of where I put my Stock Horn cover...
Old 03-22-2009, 06:11 PM
Tx_Outlaw's Avatar
Tx_Outlaw
Tx_Outlaw is offline
I've been running my coil in that location for about 2 years now. No issues with heat even in traffic in Texas.......
Old 03-22-2009, 07:55 PM
JohnK-NJ's Avatar
JohnK-NJ
JohnK-NJ is offline
Looks good. I wonder if they sell a killer looking coil that you can mount in the same location.
Old 03-22-2009, 10:10 PM
RedBen's Avatar
RedBen
RedBen is offline
Exile cycles has relocation kits for both horn and coil. They put them back by the splash guard.
Old 03-26-2009, 11:07 PM
JayDee5150's Avatar
JayDee5150
JayDee5150 is offline
Does anybody know if the Rocker coil will work on the older Heritage Softails? The Rocker has this type coil set up right out of the factory, and the way the coil sits the wires run very nicely to the jugs. I did see the ignition at the top of the Rocker coil...could this just be deleted, or bypassed?
Also, the Rocker coil looks small enough to fit under the stock Heritage horn cover. If it did work, I think it would be a really clean set up.
Any thoughts?
Old 03-26-2009, 11:12 PM
dusty2221's Avatar
dusty2221
I'm sure it would work, but then the under $50 price tag would triple. I completely forgot about pics last weekend, I'll try sat or sun so you guys can see exactly what I did
Quick Reply: Relocated Coil and horn, GOODBYE seat post!!!
