Is my rear wheel crooked?
Nothing to do with adjustment. It's a vertical c,g problem. Unless you are willing to move the front wheel about 3/8" to the left from where it is and the rear about 1/2 " , as an example, which can't be done with the sprocket you just have to learn to live with it. The right lean is needed to combat the heavier on the left of center balance point of the bike due to wheel placement. This is why it will also likely take off to the left if you let go of the bars. This can all be varified with a level and trying to find where the nuetral point is for balance when sitting on the bike. Mine works out to about 1 degree. I've accepted it for now, as when a tire is worn out, it won't matter if it's dead center or slightly off center. Just the nature of the beast, and if it wasn't for the windvest windshield the 1* would not even be detected when riding.
Ron
Ron
Ron
Ron
Don't know , but in order to shove that 200 in there things need to be re aranged in order to have the sprocket line up with the gearbox. Swingarm is built to shift the rear wheel to the right considerably. Front and rear fenders are positioned to the wheels so it's not apparent by just looking at it, until you dig further. Front wheel is offset about 5/16" to the right and rear , with my quick measurement is 1/2" plus. Bottom line is left heavy bike needing right lean to go straight with right side front and rear tire wear. Bizzar, isn't it? I still love the damn thing though
Ron
Ron
Ron
Ron
I was wondering if this was why my rear wheel is also mounted slightly left of center. It is more noticeable since I've mounted the HD tri-bar LED taillight. The wheel's centerline is about 1/4" to the left of the bike's centerline.
Check the tech forum there is a thread that shows you how to make the alignment tool it is very easy to check that the wheel is adjusted properly you just use the tool to make sure the axle is centered if it is you are good but if it is not the tire would be crooked not angled so the dirt would still be even because the tire will still make contact maybe you just rode through some dirt but only with half the tire.
He's saying that the bike naturally leans to the left due to the left side being heavier than the right, so the rider compensates by leaning right. This cause more wear on the right side.
Ron
Ron
Ron, thanks for the reply. I mentioned about the upright stance because I've got a loose spoke in the rear wheel & this 'may' be one of the reasons why. I know I had a devil of a job with a sidecar outfit I had once, and we put the spoke loosening in that down to the lateral forces.
Of course it may just be one of those things..
Perhaps I ought to ride behind myself to watch one day!!
