heel toe shifter
Old 04-06-2009 | 11:44 PM
oct1949's Avatar
oct1949
If I wear my boots that has a heel I toe shift, and if I wear my flat bottom boots I sometimes use the heel shifter.
  #62
Old 05-14-2009 | 09:27 AM
Buellrunner's Avatar
Buellrunner
My Boots are to big in front to lift the toe part of the shifter. I would like to remove the heel part though.
Is there a taller shifter that I can buy?
Cheers!
  #63
Old 05-14-2009 | 11:16 AM
jimmers1817's Avatar
jimmers1817
Cheers!
Don't need a taller shifter, just need to rotate the shifter up a few splines. Easy enough. Loosen the allen on the bottom. Just make sure you put some blue locktite on it and tighten it back good. Had to do that on both our bikes. Did the same with my rear shifter also except I lowered it so I didn't have to raise my heel so much.
___________________________
2008 Heritage Classic: His
2008 Deluxe: Hers
  #64
Old 05-14-2009 | 01:56 PM
BTL's Avatar
BTL
Maybe I am just lucky but never had a problem with my heel to toe shifters and its been well over 20 years, lol not to brag I do wear 13 size boots( here that ladies) lol.
  #65
Old 05-14-2009 | 02:15 PM
Jip's Avatar
Jip
Originally Posted by Savagehenry
I just lowered the heel shifter on my 'Bones so that it almost touches the floorboard when I shift. It seems better than the factory setting, but admittedly the jury is still out on whether I keep it on for the long haul.
+1, they set them too high from factory, adjust it down and no problems
  #66
Buellrunner
Thanks Jimmers!
Regards,
Jack
  #67
Old 05-14-2009 | 04:11 PM
Heritage Lady's Avatar
Heritage Lady
I really like the heel shifter. It's just fun to use. I seem to use the toe shifter for maybe 2nd and 3rd and the heel shifter for everything after that.
  #68
Old 05-14-2009 | 04:22 PM
128auto's Avatar
128auto
I seem to use my heel a lot to downshift when my toe rests on the hwy peg, kinda cool lol.
  #69
Old 05-14-2009 | 04:40 PM
harleyflyboy's Avatar
harleyflyboy
This is my 3rd Harley and the first thing I do is remove the heel shifter. Then add a spacer to move the toe shifter out to the end of the rod, it makes the toe shifter much more convenient. I just use PVC painted black cut to the correct length.
  #70
Old 07-20-2009 | 09:40 AM
HarleyCamper's Avatar
HarleyCamper
It seems the best of both worlds would be to install the folding gizmo so you've got it when you want it or it's out of the way when you don't. The strange thing to me is that the one that H-D makes only swings partially out of the way.
And the one that Kuryakyn makes goes totally out of the way.
Anyone tried either of these or preferably BOTH of these? I'm not even sure the Kuryakyn one is available yet. The catalog says: available in July 2009.
Quick Reply: heel toe shifter
