Braided stainless fuel crossover line
quick question. i am installing a stainless braided tank crossover line. i got the one from the HD dealer.
when i snug down the furrell according to the directions, the hose does not get tight. it will still rotate a bit. is this normal? i don't want to over tighten it and break it, but i want to make sure it doesn't leak!
thanks
thanks
Bought mine from a guy here for $15 shipped. I think they are like $35-$40. Worth it if you take your tank off to do stuff. Removed my tank 3 times in 6 months for 3 different reasons. Will be off again some day when I go BB and milled heads! lol
When you going to update your sig with that sweet lookin white ride!
$30, i got the one for the touring models. the rocker and deuce use a 7" line, which Harley doesn't offer. The one for the standard softails is 6", too short. My bike has a 2" tank lift on it. The one I got is 9" so it should be perfect. tank is still off the bike, when it is all done. i will post results.
thanks for the info on tightening it. i guess i will tighten it a little more
Dennis Kirk has a 7" line for $42.99, part number 18-2997 or you can check out Magnum Sterling Chromite II for all Rocker cables or lines.
