Which bumpstop for Rocker...
Old 03-06-2009, 07:25 AM
kylant's Avatar
kylant
kylant is offline
Default Which bumpstop for Rocker...
are you guys using when using a lowering kit or the Heartland kit? I know it is lower profile, but what bike is it from? Softail custom?
thanks
Old 03-06-2009, 03:36 PM
MartyF's Avatar
MartyF
MartyF is offline
Default Bumpstop
Kylant,
The Heartland kit for my Rocker C came with a bump-stop specifically for the EZ Rocker conversion. This does not lower the bike, but it gives more play within the suspension so it does not bottom out (hit the thicker stock bump-stop) as easily, which increases ride quality. This helps to compensate for the lowering. Because the bike itself must be lowered and for that I'm using the Progressive 422 shocks that are adjustable from 0" to 2" for lowering.
Old 03-06-2009, 03:43 PM
kylant's Avatar
kylant
kylant is offline
Originally Posted by MartyF
Kylant,
thanks man, but i know exactly what you said. i need the thinner bumpstop for the exact same reason heartland provides one. i have the bike lowered already and would like a little more travel, hence the reason for the smaller bumpstop.
Old 03-06-2009, 04:34 PM
MartyF's Avatar
MartyF
MartyF is offline
Default Bump-stop
Kylant,
OK, I've got it now.
Try contacting Heartland - maybe they could either sell you the bump-stop separately, or recommend which one to get. They are nice folks to deal with. You are right, since you have already lowered the bike, the thinner bump-stop should help improve ride quality.
Old 03-06-2009, 05:02 PM
MadScot's Avatar
MadScot
MadScot is offline
Someone posted this elsewhere. Can't find the thread now but thanks to the original poster. I've done it but haven't been able to test it yet.
"Standard softail bumpstop mounted on a piece of 1/4 inch plate. You have to drill and tap the mounting holes in the plate."
Old 03-06-2009, 05:04 PM
57RebelRocker's Avatar
57RebelRocker
57RebelRocker is offline
heartland will sell you the bumpstop
Old 03-07-2009, 09:35 AM
kylant's Avatar
kylant
kylant is offline
the thinner bumpstop heartland uses is the one used on all other softails except the rocker. for some reason, the rocker uses a thicker stop. i called heartland and got this info. the things costs a whole $5 at the dealer. mines on its way
Bslickwilly
07-29-2011 11:15 PM
DMorr99
12-23-2009 10:32 AM
08rock
09-05-2009 10:29 PM
09BlueRoadKing
05-02-2009 03:11 PM
rocker00
02-18-2009 04:30 AM
Quick Reply: Which bumpstop for Rocker...
