Shifting/clutch PITA
Since I changed the clutch cable (ape install) it is a PITA to shift the gears to neutral, it goes from 1st to 2nd and viceversa skipping "N"... no problem when the bike is turned off... Any of you have the same issue? You think it is a cable or a primary adjustment???
Mimo.
Mimo.
You need to put slack in the cable adjuster, open up the clutch cover. Break open the nut with an 11/16 socket. Use a 7/32 allen wrench, turn it in until you feel resistance, then back it off 1/2 a turn. Lock down the 11/16 nut. Pull the clutch lever make sure it is seated, then adjust the cable slack.
Mimo.
It's funny you posted the question Mimo, I started searching for this exacty topic last night. My bike has decided since the apes that it does not ever need to go into neutral. For real, I pull up to a gas station and go from 1st to 2nd at least 10-15 times before I get neutral. Never had the problem before.
Yes, the cable lenght may come into the problem.... whatever the apes are comfortable and looking great
Mimo.
