Shifter not returning
look at the forward part of the shifter assembly. the linkage connects to an arm, the arm connects to a shaft that goes through a housing, the shaft connects to the shift arms. where is goes through the housing needs oiled. if you got dirt or rust you may have to take it apart and clean and lube. that's where my problems was. I sprayed it out with brake cleaner several times and lubed with some liquid wrench. I have not this the problem in the last year and half.
Gents...thanks for the help. I removed the linkage..and the snap was great. This told me it was the linkage. I see now what you're referring to...later on I'll remove the shifter...and clean the shaft with some sandpaper and maybe even mill it a little...there is no grease fitting so maybe it just got fed up with the dirt..and revolted :-)
If I were you I would just pull the shifter apart to clean things up with some emery cloth and consider adding a grease fitting.
Getting rid of the original shift rod for a new one with Hyme joints on the end isn't a bad idea either.
I haven't had a problem with mine, yet. But I already replaced the stock shift rod with the polished stainless steel version Harley has in their catalog. It made a noticable difference in how it feels when your stifting gears.
Doesn't look bad either.
When the bike is clean anyway.
