Progressive Front Drop-in Lowering Kit?
Yeah, they make it look so easy on the video for those drop in kits. I was excited as hell, until I found out it wouldn't be that easy for us Train owners. Oh well, just a chance to drink more beer
It's starting to look like this may well be a job for a snowy/rainy day which will be back soon enough here near Chicago. The weather is supposed to be in the 50* area Wednesday through Saturday, so I don't want to get the bike apart and run into problems. Just opened up the service manual and got a little intimidated by it...Suppose I'll know more when the parts come. If the brake caliper needs to come off I may put some Lyndall pads on it and the rear while it's apart.
Man, sounds like you will need a snowmobile . Yeah, I too will be in no hurry, since it will still be awhile before I can ride here also. Everyone who is doing this drop, please post some before and after shots. Thanks!!
Hey All, I just did mine last week on my 2008 TRAIN. You do not have to take the forks apart!! Take the weight off the front wheel, remove the caps on top of tubes, remove chrome cap in middle of tree, remove large nut, remove top tree (lift straight up), remove second plug on each fork leg and wa la there are your old springs. install new spring, the compensater spring,washer, PVC pipe, washer. Then reinstall tree, nut, caps, torque to specs. your done!!! I cut the PVC to the minimum the instructions said and i got 2 1/4 inch drop on my front end. Handles much better. Not a big job, took me about 55 minutes and 2 beers. No big deal at all.
