Stage 1 - Lost Power! WTF?!
Dang bro I aint never heard craziness like that, dont know much about a TT tuner, is that one of those closed loop self tuners? Call them, even Freedom,
where did you get your perf #'s or dyno results, they didnt know either, hell call someone, and if they cant help call 911 cause you got robbed!!!!!!!!!!!!!
I really can't believe that your exhaust would cause you to have lower numbers from stock. I'm sure you would lose a little hp & tq from the exhaust you choose but no way would should it be less than stock #'s after a dyno tune. I would say take it back and tell them to get it right. But you would probably be better off finding a different tuner. That sucks dude! No way a good tuner would have let your bike leave his shop with those numbers. How many runs did they pull on the dyno?
If your exhaust is turning brown, its because you are too lean and when a motor runs lean, it loses some power. See if you can't dial in a little more fuel, that will cool the exhaust down and probably give you more power. Good luck with getting the color out of your pipes. I personally never had any luck at it.
