Stage 1 - Lost Power! WTF?!
one important piece of information is missing from the dyno sheets, the AFR readings...
what's the AFR on those runs??
also look at the time stamps on the different runs, there was only about 15min between two of the runs, is that enough time to tune?
looks like they just loaded a new TTS map, ran it again and sent him out the door..
your mapping is wrong it way too lean i had the same problem with the new download it correct it. i have 07 110 se ultra stock it pull 87 hp and 102 tor with stage one and correct down load it pulling 92.5 hp and 107 lb t. the first download to the emc was way off runging too lean stalling at red light exhust trun brown ran hot. put in a new download correct the probem temp drop in half hp when up. lost mpg a lot 5-10 mpg
find a new danyo mach and tuner my air to fuel mixture is 13.28 to 1. before it was 13.9 to 1
PCIII has a map for that setup and I am selling my PCIII
https://www.hdforums.com/forum/softa...ley-170-a.html
You went back to The Cycle Doctor and he gave you the download? He didn't offer to do it for you? I'm interested because I've used him and was thinking of using him again. Thanks.
I don't understand your questions. I went back and obtained the files from the dyno tuning session that I paid for.
