"Stick Tricks" for no knurl apes
Old 02-23-2009 | 07:52 AM
DaddyKnuck's Avatar
DaddyKnuck
Originally Posted by old skool1983
i'm having this same issue, can someone explain beer can shims to me? on an old set of bars i used my buddies MIG and we just threw some tacks on the bars where the risers go. i just cranked mine back down again but if they slide i wanna try somethin
Cut strips out of your favorite beverage can about 1 inch wide. Narrow enough so that they won't be seen, but wide enough to give you some grip. The circumference of a beer can allows you to wrap the bars about twice with some left over. If you want to its OK to secure the strips with a little tape to hold them in place. Depending on how worn your risers are you may need to do this more than once. My brass ones are pretty sloppy and I think I have three layers of strips. Whenever you have enough in there, tighten up the bolts and the riser will compress the aluminum. It's been working for me for a long time that way. You can use aluminum flashing if you want, but a beer can is cheaper. BTW, cranking on the bots if there is not enough contact isn't going to tighten anything up. Better to build up the surface with shims and not risk breaking a bolt. More is better than less.
Old 02-23-2009 | 08:22 AM
old skool1983's Avatar
old skool1983
thanks man, if she slips again i will do it
Old 02-23-2009 | 08:28 AM
DTM_75's Avatar
DTM_75
6th Gear
The beer can shim trick is: cutting a few strips of aluminum can and tightening em between the bar and risers. The aliminum is pliable enough to smash down between them, and gives resistance against the steel of the bar and riser. I don't know why aluminum resists slipping against other metal, but it does.
Old 02-23-2009 | 08:35 AM
DTM_75's Avatar
DTM_75
6th Gear
Originally Posted by DaddyKnuck
Back when beer cans and oil cans were made of steel they were the basic building block of just about any kind of motorvehicle.
yeah I know all about that kinda "customization". I used to mess with old VWs, my old split window bus was held together by everything from bailing wire to street signs.
p.s. ... looks like we were both replying to the beer can shim question at the same time. I have to say, you did a better job though. LOL
Old 02-23-2009 | 11:59 AM
DaddyKnuck's Avatar
DaddyKnuck
We need to keep passing the knowledge along to the new generations. Next week's lessons are brazing with coat hangers, creative uses for JB Weld and what to do when you lose you master link clip.
Old 02-23-2009 | 12:07 PM
louddmax's Avatar
louddmax
if you mark your riser locations vise-grips make pretty good knurls.
Sincecrazy
06-07-2015 05:47 AM
rgjujitsu
01-02-2014 06:48 AM
RedBen
04-02-2012 07:32 PM
yandeltx
08-12-2011 06:19 AM
DocJ
08-13-2010 07:10 PM
Quick Reply: "Stick Tricks" for no knurl apes
