Inverted front end
Old 03-03-2010, 02:20 PM
masar's Avatar
masar
masar is offline
Where to get such front end for price under 1 K ? Exactly what i want to have. This one is for 3K.......
Old 03-03-2010, 02:59 PM
MCSarge's Avatar
MCSarge
MCSarge is offline
Send a PM to Joe and he can provide you with all the details on his swap. If you do a search under his name you will find the past posts on how his ride was done.
I have the same front end but I ordered the 0 rake and standard softail length for my 87 FXLR. The forks are about 1 3/4" longer than the stock forks but I am going to run a 16 inch wheel instead of the stock 21 so it should be okay, and make the bike sit more level than the old style bikes used to. I did have to cut the pivot bolt down 3/8" because the Softails used fork cups (7 3/8" measurement) and my bearings are mounted in the steering head so it was only 7".
I purchased the front end from Jerih(sp?) Cycles for 485.00 and free shipping. Beautiful front end, massive with really nice chrome and it uses stock HD internals. Good luck with your project.
Old 03-03-2010, 04:27 PM
masar's Avatar
masar
masar is offline
I already contacted Joe via PM and he gave me all info, thanks a lot Joe btw your box is full..... But the point is that this front end on picture is different - much more wider and the difference seems to me huge. I realy love it except the price.....
This one is also nice
Old 03-07-2010, 11:47 AM
masar's Avatar
masar
masar is offline
I found Ton Pels signature Fat Bubba forks for about 1,3K. Currently cheapest fork with fat and clean look i was able to find. Picture attached. If aynyone know other option, would be great.
Old 03-07-2010, 11:49 AM
masar's Avatar
masar
masar is offline
forgot the picture
Old 03-07-2010, 02:33 PM
CyberDuke's Avatar
CyberDuke
CyberDuke is offline
Looks like the Bodacious 65mm inverted forks from Ame Chopper kit: http://www.chopper-kit-usa.com/bodacious.htm
Old 03-07-2010, 02:56 PM
masar's Avatar
masar
masar is offline
They say 2,6K for these. Plus the design is not so smooth.
Old 03-12-2010, 04:44 PM
masar's Avatar
masar
masar is offline
Just refresh if anyone know about fat wide clean front end for price under 1K. I am searching but still can not find cheaper than the Fat Bubba. BTW i need black one....
Old 03-14-2010, 01:50 AM
masar's Avatar
masar
masar is offline
i found this Big-Un front end for price under 1,3K. Any experience?
Also found price 1060 usd for this front end on web, sounds good. Price on that link below is expansive but there is good desctiption.
http://www.steelthundercc.com/frontend.html
Old 03-14-2010, 07:30 AM
WWECOUGAR's Avatar
WWECOUGAR
WWECOUGAR is offline
Inverted front forks are to reduce unsprung weight and improve handling accordingly. There is no advantage on a Harley Softail. Unless you just want something different. Seems like alot for little to me....... My $.02
Quick Reply: Inverted front end
