I have a 2006 FXSTSI Softail Springer. It came with the 200mm rear tire. Do any of you know what size pulley and tooth count is on that rear end. I am searching for a chrome one and need to know what the size and tooth count are in order to order one. Thanks for any help!
you will need a 7/8" pulley to use the 20mm belt and 70 tooth since its a 5 speed. Make sure you CONFIRM that the manufacturer actually makes the pulley in that tooth count, since most bikes with 20mm belt are 6 speeds.......
Took me 6 months to find a mesh pulley with those specs.....
