New Battery tender
![Smile](https://www.hdforums.com/forum/images/icons/icon7.gif)
Batteries will self discharge over time and with the new bikes and the security systems on them they discharge at even a higher rate. A battery will only take so many discharge/recharge cycles, so if you keep the battery up to full voltage, you keep the sulfation rate down on the lead plates within the battery. This is what a battery tender is designed to do--keep the voltage constant and at its prime voltage.
Do not worry about drying out the battery with a battery tender. The recharge rate is so low that the battery never gets warm and the water within the cells does not evaporate. The newer technology gel cells do not release much water vapor to start with, so this is not really a problem. If you do heavy-hard recharges then you will open the pressure release valves on the gel cells or absorbed glass mat type cells and it will dry them out. A battery tender is not high enough amperage to do this damage.
Like they said plug it in each time you aren't using it and then forget it.
Good Riding!
Good Riding!
salty_rider
04-16-2015 06:14 AM
