Panecea Taillight only?
Can I run a Kuryakyn Panecea taillight by itself without outboard turn signals? Is there a resistance thing i need to worry about? 2001 FLSTFI
I am removing the front signal bullets and putting on a set of LED signal mirrors as well, so bye bye bullets...just wondering what I need to do to fool the wiring into working.
Becareful, some states require at least seven inches between right and left turn signals. I've seen a lot of bikes running just the tail lite with the integral turn signals and they probably haven't had any problems. Might want to check the vehicle code in your state. IMO they just don't make you very visible in the daylight.
