Adjusting the angle of fog lamps
Old 01-29-2009, 09:56 PM
Smorphine's Avatar
Smorphine
Smorphine is offline
Default Adjusting the angle of fog lamps
How does one adjust the angle of the fog lamps?
Thx
Attached Thumbnails Adjusting the angle of fog lamps-hd-softail-aux-lights.jpg
Old 01-29-2009, 10:10 PM
spooner's Avatar
spooner
spooner is offline
If you remove the lamp, on the inside of the housing is a nut that needs to be loosened. Adjust the light to where you want it, then re-tighten the nut.
Old 01-29-2009, 10:46 PM
keno's Avatar
keno
keno is offline
there is a special hollowed out/notched socket made by snap-on tools made for it. What it does is allow the wire to go to the center of the socket so you can loosen/tighten the nut for adjustment. by the way, that socket is like 40 or 50 bucks. I made my own out of an old socket and a dremel cutting tool..
Old 01-29-2009, 11:25 PM
Smorphine's Avatar
Smorphine
Thanks for the quick responses.
That socket is pricey eh?
Old 01-30-2009, 01:51 AM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
My palm has always worked very well. Just tap it down or up to where you want it.
Groucho1
08-31-2015 01:58 PM
zoood
05-03-2015 04:13 AM
slime_dog
04-08-2010 07:20 AM
dbird
07-24-2009 12:13 PM
corgi
01-07-2008 05:48 PM
Quick Reply: Adjusting the angle of fog lamps
