Back Firing
Back Firing
I posted this in another thread topic but only one person replied so I thought that maybe I might get more feed back here.
Have a 07 deluxe that I put V&H long shots on w/AC and SERT and had dyno. It is now popping with I decel and seems to be getting worse. I did check the intake and the bolts were a little loose but still does the same thing. I know other have put V&H on there scoots but not SERT and did the fuel pack and no dyno and theres dont pop.
Can a dyno jump timing or do you think it might be something else? It is starting to drive me crazy when I down shift or even let of the throttle and it poops.
Any ideas???
THANKS
Any ideas???
THANKS
With the SERT your Dyno guy should be able to get rid of the popping on decel. Mine did the same thing, drove me nuts. I have the USB PC III, and with the help of another member here (Faction95) we added a little fuel to the 0% columns on both cylinders from 1200 t0 4000 RPM'S. That cured my popping on decel as the machine was running to lean at 0% throttle.
Now it just gurgels on decel sometimes, but runs strong, pulls hard.
So I would guess your bike is lean at 0% Throttle.
Had rush pipes with sert, when I bought the bike, and it had popping on decel in 3-4 gear going down hill, like a hillbilly!!!! Dealer #1 said it was normal.
Switched up to Vance and Hines with same sert, still getting alittle popping on decel in a higher rpm decel. Set up and tune from a completely different dealer # 2,
I have not dyno tuned yet, And was not pushed into getting one, What a freaking suprize that was and they told me that it may, or may not remove the decel pop.
Also in reading on the subject, that if you do get minor decel pop, thats a good thing, as long as it is not coming from the headers. Its all about balancing the lean and the rich, Air and fuel ratio. If you are not seeing a dramatic decrease in fuel. MPG's and maintaining the same you may be in a happy place. You basically may have to take the bike out of tune to take away decel pop.
Cant answer if this is a common issue with Rush slip on, or Vance and hine, but I have it, the same problem of pop, And living with it for now.
Theres alot going on with Harley changing to EPA Laws, and some Tuners working better than others with exhaust and air system changes, as with many on this forum, ......
Trial and error, and found what works and doesn't. It SUCKS that some have forked over bucks for a sert and buying a high end exhaust system V & H, and still have issues...... WTF!!!!
