Carb problem?
01-19-2009, 03:31 PM
Carb problem?
I've got a stock Mikuni 42 0n my 04 Deuce it will run ok off the line but when I get to a high speed it seams like I have a governor on it. It just flattens out. Is it a carb problem? Thanks any ideas? Thanks again.
01-19-2009, 03:37 PM
Lean or partially clogged Main Jet?
01-19-2009, 03:45 PM
Maybe I'll look how about a pin hole in the diaphragm on the vacuum piston
01-19-2009, 03:53 PM
Mikuni's have a mechanical slide, not operated by vaccuum like CV's.
01-19-2009, 04:17 PM
OK thank you for your help
01-19-2009, 04:29 PM
Maybe you meant it has a stock Keihin C.V. carb and I misunderstood. If it is a C.V. carb it's a Kehin, not Mikuni. And yes, a tear in the diaphragm or if the diaphragm isn't seated correctly, could definitely cause this issue!
http://www.johnsmotorcycleparts.com/...tor-images.htm
01-19-2009, 04:33 PM
I might have mislead you myself thanks again I'll look into it
01-19-2009, 04:36 PM
To make sure that the diaphragm stays put while I put the top back on I use a little gasgacinch or rubber cement.
01-20-2009, 06:46 AM
pacman552sd
Carburetor Related
06-03-2015 10:39 PM
chardagha
EVO
05-03-2010 04:28 PM
sandman2004
Carburetor Related
02-17-2009 03:04 AM
dgator@ymail.com
07-11-2008 10:20 AM
Beeracuda
Exhaust System Topics
13
12-27-2005 03:16 PM
