Which Heartland E-Z kit for Rocker C
Guys,
I am away to order the Heartland Seat Conversion Kit for my new 2009 Rocker C, but the Heartland webpage has many options.
Which option is it that I need?????
E-Z Rock-R Conversion System – Fits 08 Rocker & Rocker C
includes: struts, fender, seat, rock guard Retail
HL-240R Chrome Struts and Wild Heart Fender 11 x 20 $1,999.00
HL-240RPC Powder Coated Struts and Wild Heart Fender 11 x 20 $1,999.00
HL-240R-1 Chrome Struts and Heartbreaker Fender 11 x 24 $1,999.00
HL-240R-1PC Powder Coated Struts and Heartbreaker Fender 11 x 24 $1,999.00
HL-240R-2 Chrome Struts and Heartlander Fender 11 x 28 $1,999.00
HL-240R-2PC Powder Coated Struts and Heartlander Fender 11 x 28 $1,999.00
HL-240R-3 Chrome Struts and Heartlander Fender 11 x 28 $2,398.00
With frenched in tail light and license plate frame
HL-240R-3PC Powder Coated Struts and Heartlander Fender 11 x 28 $2,398.00
Block 2J-GTE
Piston Standard
Piston Ring Total Seal
Connector Standard
Connector Bolt ARP
Crankshaft Standard
Bearing Clevite 77
Intake Camshaft Stock
Exhaust Camshaft Stock
Camshaft pulley HKS
Valves Standard
Retainers Standard
Spring Valves Standard
Pulley Red anodized aluminium
Crankshaft Pulley ATI Pulley weight balance
Turbo Greddy T78-33D
Waste Gate Greddy Type C
Blow Off Valve Greddy Type R
Throttle Red anodized aluminium 80 mm
Head Gasget Cometic Multi Layer Steel Gasket 1.3mm
Header Greddy
Intercooler Greddy Spec M 4"
Intake Manifold Veilside
Exhuast Muffler HKS Sliencer
Radiator Aluminium Custom Made
Oilcooler GReddy GREX
Fuel Pumps Walbro 255 l/hr x 2
Injectors SARD 650cc
Fuel Rail Custom Made Red Anodized
Regulator HKS
Oil Pump Standard
ECU HKS F-con V Pro
Spark Plugs NGK Racing # 9
Spark Wires Standard
Ignition Expanding Standard
Replace all hoses/pipe work with Red hoses
Anything that could be polished was polished
Transmission
Gear 6 Speeds standard
Clutch ORC tripple plates
Flywheel ORC
Final gear 3.266 : 1
Limited Slip Cusco 2 Ways
Suspension
Front Shock Absorbers HKS Hypermax ll
Rear Shock Absorbers HKS Hypermax ll
Front Spring HKS Hypermax ll
Rear Spring HKS Hypermax ll
Front Brake Brembo F40
Rear Brake Standard
Brake Pad Project Mu
Front Wheel Weds Kranze Borphes SMB 19 x 9.5 + 28
Rear Wheel Weds Kranze Borphes SMB 19 x 10.5 + 16
Front Tire Toyo Vimode 245-35-19
Rear Tire Toyo Vimode 275-30-19
Exterior
New TRD Wide body
New Paint Job
New Xenons Lights
Interior
Guages Defi BF (Boost, Fuel Press, Water Temp)
Boost Controller Greddy Profer B Spec II
Wheel Steering TRD Airbag
Gear HKS
Driver Seat New Leather with red stiching
Passenger Seat New Leather with red stiching
Belt Standard
New Carpets
I'ts the...E-Z Rock-R Conversion Kit
Part # HL-240R-1.........$1,999.00
License Plate Holder-Side Mount
Part # HL-3005C1.........$219.00
LED Plate Light
Part # HL-3001C...........$59.00
Turn Signals Medium Billet-Tears
Part # HL-5002C...........$239.00
(Need to ask for the rear mounting bracket for turn signals)
I hope this helps..good luck brother you'll love the conversion and thanks for the compliment on my bike.When you get all done post some pics so we can see how it turned out.Almost forgot,ask the salesperson if you will be needing the Illuminator on your bike I did.This part helps run the new turn signals like the stock ones did...as brakes,turn signals and running lights. The parts name is..Badlands Illuminator.
LED Plate Light
LED Plate Light
LED Plate Light
By the way those pipes are also ******* awesome as well (who make them) are they loud, I love loud pipes
Below is a picture of my old bike **** I miss it
The pipes are Martin Brothers Shockwaves...they are loud...I had Vance and Hines originally on it...took them off and put the Shockwaves on...got 5 more horses and more torque...I have included a pic of the dyno map...the V&H's are the lower map the Shockwaves tore them up in both charts....and yes you will have to lower the bike for the heartland kit to look right and fit properly...I too put Progressive 422s on mine...although you can go anyway you want on lowering it, but you need to lower 2 inches to achieve the look... the blue lines on the dyno map are the Shockwaves and the red lines are the Vance and Hines Big Radius's you be the judge on which are better...lol...i can see why you miss you old scoot extremely nice bike
JAFlanders
Vendor For Sale Classifieds
10-15-2016 08:52 PM
