flush mount fuel cap on Heritage Classic - How hard to install?
Old 01-14-2009 | 04:30 PM
Mordrapheus's Avatar
Mordrapheus
Default flush mount fuel cap on Heritage Classic - How hard to install?
Have been thinking about getting myself a set of the black flush mount fuel caps for my black heritage classic (2009 model) (EFI of course).
How hard are they to install? Anyone done a photo installation intruction/walk-through?
thanks
Old 01-14-2009 | 10:48 PM
Mordrapheus
shame I was hoping someone might have something...just curious whether it is an easy exchange on the left side with the fuel gauge or if there is a whole bunch of wiring to do
Old 01-14-2009 | 11:43 PM
gonetoTDC's Avatar
gonetoTDC
There is a thread in this forum about flush mount caps. It should answer all your questions..Hope this helps
Old 01-15-2009 | 12:18 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Its a real no brainer install. The 'hard' part is getting the new wires through the tank. But if you tape a piece of string to the old wires when you pull them out. You can use that same string to pull the new wires down through.
Make sure the top of the tank is clean and wax free around the gauge and gas cap before you stick the plastic outer ring down or it might come loose on you later.
The only real wiring is putting the new plug together and pulling or cutting one wire out of the speedo connector. For that your going to have to take the one nut off to lift off the dash.
Do a search, in the last week someone wrote out the instructions for another guy to put on the stock 'looking' LED gage. The procedure is identical except for the part about adding the trim ring for the flush version you have.
Old 01-15-2009 | 12:47 AM
BTL's Avatar
BTL
I would love to get a set for my Cross Bones, but from what a lot of the forum members write, there are a lot of problems with the led's going bad on the harley flush mount caps, so I decided to hold off from buying them untill i here the problem is taken care of. Just my .02 cents worth.
Old 01-15-2009 | 12:59 AM
Mordrapheus
call me silly but I just can't find that thread
Old 01-15-2009 | 01:11 AM
Try looking here;
https://www.hdforums.com/forum/softa...uel-guage.html
There are a couple of sets of directions in the thread for you to check out.
Old 01-15-2009 | 01:27 AM
Truckbizz's Avatar
Truckbizz
Account Deactivated
Very simple and they look great!
Old 01-15-2009 | 08:08 AM
Deuce Bigelow's Avatar
Deuce Bigelow
I don't think the new flush mount gauges have the "low fuel" wire that goes to the speedo anymore....
so it's an even easier install!
Old 01-15-2009 | 05:26 PM
Mordrapheus
Citoriplus --> you'r the best thanks
Quick Reply: flush mount fuel cap on Heritage Classic - How hard to install?
