little clutch ? for you..
I check the DIY and other posts on this with no direct answer to my ?..
I did the apes and all in the basement put the clutch cable on and adjusted to 1/8" cable play.........has sat for a while anyway went down to recheck everything today and decided to see if the clutch was right(not running) I put it in gear pulled the clutch in and nothing,the bike will not roll,took cover off and checked the pawl and *****,clip in right spot put all back together and adjusted cable and still the same,clutch feels good but does the same thing.
Do I need to adjust the clutch itself....or is it something I over looked....
its a 06 softail.......
didnt think you would have to adjust the clutch itself with just a cable swap.
You will have to adjust the clutch from what you are saying about your issues. Here is a link to help you out. http://www.expertvillage.com/video-s...aintenance.htm
