Chrome Splash Guard Help
Rusty,
I saw WARG's thread yesterday as well and looked into it (HD part 60476-00A) - $35.04 from Zanottis.
If you do get it done, could you post a finished pic please... though i'm not far off needing new rear tyre so i might hold off and get the stealer to put it on for me as its near impossible to get my hand inside the fender with my 200mm rear tyre, i need my wife to help me get the sissy bar on and off as it is.
Regarding the license plate plastic, that seems to be fastened by 2 bolts under the fender. Does anyone know if this can be taken off as well, and if so, how to you affix the license plate back onto the rear (without going for a side mount plate option)?
Shupshe (07-23-2021)
FXSTD.AU As soon as I get measurements, I will make the diamond plate one and post a picture. As far as the plastic license plate holder, I do know that the plastic that is under the fender acts as a holding area for a bunch of wires. If you remove the entire bracket, you'll need to find a way to secure the wires. If your Deuce is a 2000-2006, they make a chrome repacement for this bracket. If your bike is a 2007, Harley has a chrome license plate mounting bracket that mounts over the black plastic that hangs down. I hope this makes sense. The full replacement chrome piece does not fit on an '07. Rusty
Here's the measurements for placement of the holes, as best I could measure:
Top Left: 1 1/4" right, 3/4" Down
Top Right: 1 1/2" left, 3/4" Down
Bottom Left: 1 3/8" right, 1 3/8" Up
Bottom Right: 1 7/8" left, 1 3/8" Up
Hope your not thoroughly confused. I measured facing the plate from the rear of the bike. Looking towards the front end of the motorcycle.
Rusty,
... my 200mm rear tyre....
