Wiring Heartland Lights???
ok now you guys lost me i just installed a heartland kit also now im gonna do the lights.....................kinda confuzed cuz i have an 07 NT with the tribar taillight and everything plugs into it..........do i have to take the block out of the tri bar and split everything off that.............can someone post pics of how they split everything off that plug under the seat..................that would be kick *** thanx
my bike has two tailights. Both are run,turn, and signal. The heartland lights I am talking about are for the rear. Those have orange, red and black wires
The European versions (or perhaps all export versions) of the Rocker have three rear facing lights, two indicator lights (amber) and one run/brake light mounted center on the fender.
If you install the heartland conversion for the export versions you loose the run/brake light. so either you will have to modify the sidelights to include run/brake with turn (which is illegal in the Netherlands, don't know about UK) or you will have to add a new center run/brake light.
I am doing the last with a LED array, will post pictures when its ready...
J33PTJ we cant use running lights in the UK either ..in fact i did not even understand what a running light was until these HEARTLAND indicators/turn signals arrived.mine had running light wires on but i just cut them off..i also put HEARTLAND lighted sidemount plate on mine....i suspect KYLANT has got built in rear light on his rear fender "HEARTLANDER"
well now i am confused because Heartland told me in writing (still have it) that you dont need illuminator
