Tur signal flashing fast
I have a 2008 Softail Custom and since the snow is on the ground and weather is not great for riding I figured I would do some upgrades to the ride. I installed LEDs (front and rear to include brake), triple play module and Street Magic Signal Stabilizer from Custom Dynamics. The problem I had was that my turn signal indicator lights and my security system light on my tank display stays illuminated when the bike is running. So the troubleshooting began:
1. I called CD and they had not experienced this problem before.
2. I removed the triple play and had the same problem
3. I removed the triple play and the signal stabilizer and the problem still remained.
4. I re-installed my stock bulbs and now my left turn signal (with bike running) flashes very fast.
Any ideas?
Any ideas?
I assume that signal thing is the load equalizer. Now that you have put everything back the way it was, it still doesn't work right? Have you disconnected your battery, after you put every thing back to stock? If not, you should try a momentary disconnect, of your bike's battery. This may reset your ECM.
I put LED rear signals and a Biketronics Tailbones signal converter, on my bike ,without using a load equalizer. The add in the J&P catalog made it sound like I didn't need one. After I had hooked everything and before starting up the bike, I called Biketronics and they said that J&P had the words in the add wrong.
They suggested I try a momentary disconnect of the bike's battery, then hit each signal for about 5 seconds. They said the signals may start blinking fast, then slow to normal because the ECM had some adjustment and may adjust enough for them. I did as told and everything worked fine.
Tom
Tom
matthew101376
07-05-2009 03:57 PM
battery, change, equalizer, fast, flashing, harley, information, left, load, magic, signal, stabilizer, street, troubleshooting, turn
