88 Heads and Cylinders
Maybe $150-$200 for the whole set. Check your local indy to see if they have any. Where I'm at there a dime a dozen. Hell I have a set of stock heads & cylinders for a 96" that have less than 3500 on them. If you get them diamond cut, go for the (show) cut. It's a $100 more but worth it. I had mine done and would recommend it if your looking for some extra bling.
Jugs are not worth much- $50/$75. Jugs are readily available here, craigslist, eBay...
If the heads are off an 06, they are something as is - stock and with only 4ooo miles. The exhaust port is a bit larger, valve seats were improved... much better heads than previous years. But, if you are going to have those worked on, why spend the money, just have yours worked on.
Bdhouse61
08-28-2010 11:45 AM
