Passenger Footboard Mounting Bracket with V&H BS Longs
Looking for the P/N for the mounting brackets that will work on my 07 Deluxe with V&H BS Longs. Who here has put passenger footboards on their softail when you have aftermarket pipes. Not sure if I can use the mounting bracket that the "parts book" calls for or if I need a different one. I have seen it done, but I have not got a straight answer to what I need.
If you took off the right side stock exhaust mount bracket (big chunk of steel) where your original exhaust and right side footboard mounted, you can duplicate the left side footboard set up by purchasing two brackets part numbers 52713-95A and 50481-00. The bottom saddlebag brace doesn't get put back on at least I could never find a bracket that would work for that.
http://i249.photobucket.com/albums/g...t/CIMG2614.jpg
