Front lowering kit is necessary now...
With the combination fo the fishtails, and the 21" front wheel I was scraping a bit in the twisties today. So I am going to ahve to lower my front end. I guess 2" would be ideal. I know about the progressive kit. What other kits are there and which one should I use? I am going to do the labor myself. If you have done this give me an idea of how long this takes. Thanks...Links for the kits would rock too.
Received 1,297 Likes
Guess I'm missing something here. Scraping what in the twisties? If you're scraping muttersickle parts in the twisties, lowering the front end means you'll be scraping more junk off. If you mean you're scraping the ends of the fishtails, lowering the front end will raise the 'tails a wee bit, but you'll probably drag other stuff. Best bet is to whack the head pipes a bit and shorten the fishtails. Been there, done that.
Last edited by pococj; 01-01-2009 at 09:55 PM. Reason: Completed a thought! (Don't laugh, azzhat!)
Lowering the front end will raise the rear end/tail pipes. Giving it a better center of gravity. When he installed the 21 inch front tire/wheel, it raises the front end about 2 inches.
Lowering the front of your bike will put things close to where they were when you had your 16" front wheel. 21-16= 5 /2 (wheel is round after all) =2.5 so you actually should be .5 inches higher than stock in the front end. It is possilbe you may scrape your floorboards more, but hell there on a hinge and designed to fold up. Lower it and youll be fine.
